I've recently purchased a Beolab 50 and Beoconnect Core as a streamer. In the Beoconnect Core manual it suggests using USB-C to USB-B to connect to the master for of the 50 (or 90) and then connect the master to the slave using DPL. However some sound control from the Beoconnect Core seems to be missing and the dealer says I could only get those control if I connect the Core to the 50 using Powerlink (analogue).
I'm thinking that the USB-C to USB-B should be the better way signal wise as we get the digital signal straight to the 50 and let the 50's DAC do the job, as supposed to using the Core DAC and then tranmitting the signal via the analogue Powerlink, even if it means losing some control on the app.
Which way would people recommend please?
Thanks in advance!
