Beolab 50 3.0 New Software
I have tone control, so not probably not software related
Also no sync problems, in auto
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Weird. Over powerlink input? I for now have to use the tv to regulate it but the eq/tone control does not work in the app or the web interface of the speakers. Power cycle doesn’t help either.
Sorry, I’m using Wisa
Oh, that’s probably the worst input though. I hope you at least have a DPL cable between the two speakers so the audio processors can work successfully at least. And I’d urge you to move from it to a cabled input (even if powerlink for now seem to have a bug with tonal control)
Oh, they don’t work unless they are connected with DPL cables. I had them connected with powerlink, but I like the sound better with wisa.
peter
I have no latency issues at all, set to auto and cat7 all the way
Mikipidia wrote:
I have no latency issues at all, set to auto and cat7 all the way New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Mikipedia on YouTube (finally )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I restarted them and it seems to have helped. I had some weird echo when watching tv.
gysse2004 wrote:
Oh, they don’t work unless they are connected with DPL cables. I had them connected with powerlink, but I like the sound better with wisa. peter
Actually they do but not as well. They can’t update or communicate properly when on WISA without the DPL cable between. Weird that you find WISA sound better but also interesting. It shouldn’t be but as PL is analogue I guess there is always a risk for interference especially if you don’t use the right cables.
My Lab 90s (which are wired into my router) now recognise that the new software is available, but when I try to download it I get an error message. My Lab 50s (which are connected wirelessly) cannot even connect with the server, though app control works fine.
I've asked Geoff whether he could kindly email the new software to me, so I can install it via USB.
Otherwise, I don't think I'm destined to get this!
