Beolab 50 3.0 New Software
Hi Esax,
Have You experienced the same as me with much lower BASS-response with the new software 3.0.0.0527?
Have experienced other problems than the "BASS" problem?
Best Regards
I just want to say I experience more bass. I have turned it down from two plus to zero in my beovision. My friends who listened to them both yesterday and the day before also like the sound. I guess maybe it’s a new calibration that would be helpful your you people who experience a lack of bass perhaps?
For me they sound good now anyway. Sorry to see not everyone has the same experience. But I’m hoping that it will be resolved.
I’m going to get a microphone soon so I can start doing calibrations for my house.
Martin wrote:
Hi Esax,
Best Regards Martin
Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K.
I can’t my finger on it. But somethings way of. As is I prefer my balance.
The app doesn’t work.
But you can acces the the speakers in sleepmode with wifi.
My guess:
There are quite a few beolab 50 for sale. I would think that many have complained that it is not possible to use them without neighbors being disturbed. It feels like B&O has changed the base due to that.
The sound also changed in my setup - to less bass. A bit surprising - did Geoff get new ears? 😮
I've been listening to them for a while. The punch is gone and also the sub bass.
Maybe my neighbours like them, I don’t.
Have any of you retuned them with the mic?
I lost my setting pre sw upgrade, then upgraded sw and then re tuned them and they sound bloody fantastic. Even more so than before and the punch is still there, so maybe it’s the “old” tuning file with the new sw that makes it sound extra different? Just a thought.
I lost my setting pre sw upgrade, then upgraded sw and then re tuned them and they sound bloody fantastic. Even more so than before and the punch is still there, so maybe it’s the “old” tuning file with the new sw that makes it sound extra different? Just a thought. New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
Mikipedia on YouTube (finally )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I’ll try later today.
I have not. The sound is so much improved from the update I have seen no need to, although I am a bit curious if I would notice a difference so I may do it.
Have tried - find I have to use the ‘BL5 sound design’ to get sufficient bass. May have to try a few more times.
