Consider yourself lucky, new software is buggy in wisa mode.
peter
peter
Thanks but I would never use wisa on them, thankfully 🙃Consider yourself lucky, new software is buggy in wisa mode. peter Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Hi Michael,
It seems that 3.0 sw for BL 50 is out now. Can you try to see if you have got the new update?
Best Regards
I don’t think it is placebo. The improvement is both noticeable and amazing.Update done and they sound like new speakers. Maybe placebo, maybe not.
I looked at mine and they are on 3.0.0.257. Is the 527 correct and there is a newer version than what I have? Or was 527 just a typo of 257?Thanks!the speakers could download on their own 3.0.0.527.
527, so it seems completely new.I looked at mine and they are on 3.0.0.257. Is the 527 correct and there is a newer version than what I have? Or was 527 just a typo of 257? Thanks! Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Hi Michael,
I also got the software 3.0.0.527 and have also tried other variations of the 3.0 software. My feeling is that the BASS is much less with this new software tnan the old 2.3.4.7045. What is your opinion about the Bass response?
I dont feel that the sound quality is improving. I have rolled back to 2.3.4.7045
Best regards
