Beolab 50 3.0 New Software
Speaking about this. I realized my tweeter is not perfectly centered. Not the speaker itself but the lens that moves up and down is a little more leaning towards the left side of each speaker. It has been driving me nuts. I saw my friends beolab 50 yesterday and they were the same so I guess it’s a design issue. How does your look when turned off? Is the gap between the circle perfect or tighter at one side?Mine now rise after they start playing both from the BV7 and from the Core. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
I had never noticed that, but I would say yes. If I look very closely, a vey slight lean towards the left.Speaking about this. I realized my tweeter is not perfectly centered. Not the speaker itself but the lens that moves up and down is a little more leaning towards the left side of each speaker. It has been driving me nuts. I saw my friends beolab 50 yesterday and they were the same so I guess it’s a design issue. How does your look when turned off? Is the gap between the circle perfect or tighter at one side? Beolab 50, Beolab 20, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9i, BeoPlay H6, EarSet 3i, BeoVision Avant 55, BeoPlay V1-40, BeoCom 6000 and so much else :)
BL50 bug fixes for the below are provided in 3..0.0.444
- Speakers are losing connection to each other
- Distance, Level, and Role not working
- Auto-calibrate does not work
There is also a 3.1 software out for Beolab 50. I wrote to B&O support and asked for the new software. One our later I got first 3.00 and after that update I got 3.1 update.
My impression is that You now can start and put the speakers in standby with Beoremote one or the B&O-app.
What I also noticed is that with those calibrations I have made with the old software (2.3.4.7045) the BASS is lighter with the new software than with the old software. There really is a difference.
I have also had some trouble with the new software were the speakers lost all of the calibrations I have made. I have then to make new calibrations again. So the new software is maybe better in some terms but there are new bugs. I have never before experienced that the speakers lost some calibrations.
/Martin
Does this mean one should connect the microphone and do the calibration again with the new software?BL50 bug fixes for the below are provided in 3..0.0.444 - Speakers are losing connection to each other - Distance, Level, and Role not working - Auto-calibrate does not work Ah, you know... A little B&O here, a little there
I think something happend to my speakers that should NOT happen. At first after the update the calibrations was there. Then I tried to change a calibration to a preset (using the APP) and suddenly all calibrations dissapeared. So, YES there is some bug and You might need to re-calibrate the speakers after the update.
