So my BeoLab 5s worked flawlessly for 3.5 years and then went into storage for 3 years. I recently took them out, hooked everything back up, ran the bass calibration, and played a CD.
One of the speakers immediately made a disconcerting sound (not a speaker pop, but something more digital), and does not output sound from the upper woofer. The subwoofer seems fine, and the top two tweeters are fine.
I had a service tech open up the BeoLab 5, and he removed and tested the upper woofer itself (multimeter, battery test) -- it's fine he said, no problems. So it appears to be something that is causing the electronics not to output any sound to the upper woofer.
The speaker itself shows no outward sign of a problem. It's green and functions just like my other BeoLab 5 -- without any sound coming from the upper woofer. The bass calibration also works fine, but it does appear to linger at one point -- the service tech said it was trying to hear sound from the upper woofer.
While the tech is investigating, I figured it couldn't hurt to ask if anyone has experienced anything like this before? Really hoping I don't have to spend a bunch of money on a replacement electronics module...
Thanks in advance for any ideas/input!
