BeoFab wrote:
I have read a thread about the Beolab 9's lack a little in the mids. Is that correct?
Not when they're set up correctly. I used to find BeoLab 9s actually sounded better when toed-in (which is against what you would expect from an ALT speaker). Try both. I've heard them sounding full and correct across the midband, but then I've also heard them sounding a little recessed across the mids.
SwissToni wrote:
Just out of interest how early dont the beolab 9's support the digital volume control?
Other than the PWM amplifiers, there is nothing digital about the BeoLab 9. All the crossover circuitry and signal processing is completely analog. In the BeoLab 5, everything goes through a digital stage and gets processed by a computer...
