BeoLab 5 SW verions
A very warm welcome to Beoworld..
The latest software version is 2.61a.
There have been 3 major software updates since your version 1.6.
To get the software updated, your dealer will connect his laptop to the Beolab 5's and upload it using a software service tool.
sw updates for speakers? Does this apply to the BL9's, too? I have some old BL9's which I bought second hand recently.
I wouldn't think so - the BL5 has a digital input, makes extensive use of DSP (incl. calibration procedure) and the Class D amps are, I believe, digital input) - i.e. there's an awful lot of stuff happening to the actual signal in the digital domain.
The Class D bass amp of the BL9 is analogue input and functions as a "dumb" amplifier.
I had a same problem with my lab 5's so I contacted a B&O local service center. It turns out that "EPROM" Erasable Programmable Read-Only Memory needed to be replaced. Since then I haven't had any problem with red flashing light on the lab'5.
Hope that helps.
actually i think that the new 5's are the ones that do not have the pincodes and the older models have them
