Both speakers now work with line in but not powerlink from my beocenter 2300
The one without serial number has no pin code yet it switches off after 5 mins then have to switch on again by pressing radio on beo 4, glad if technician can find out serial number from chasis will find out pin soon.
The one that works flashes green the whole time whilst playing.
I press button on top of both speakers but neithers mic works.
L-opt 0 is factory setting. Used with powerlink cables.
L-opt is for use with Line input socket and Beo4 radio command.
