Beolab 5 no sound - B&O tech next? Fuse or expensive?
Hi Roger,
I've been told that BL5 MK1 will need a full chassis swap as their old hassis MK1 are discontinued.
That means MK1 BL5's chassis will have to be swaped for a MK2 (minimum) chassis.
How much does it cost ?
I've heard around 1500/2000EUR/ per chassis.... is that amount you have spent ?
My Beolab 5 neither, I think I should replace it, sometimes this situation makes me think I have to choice another brandErm..
