Brian wrote:
Yup, I bought a 996 with the M96.1 engine for the wife a few years back. Engine went bang after a some months and needed a complete rebuild at Hartech in Bolton for the princely sum of 11K. Was a nice enough car but sold it pretty quickly after the rebuild.
Sorry to hear your story Brian.
However.. 1) There is a reason these cars come cheap. One is a mechanical mismismatch ins the IMS bearing, the resulting engine failures, and the negative hype around these. (mostly was carried by the air cooled segment of porsche, keeping quiet of their own engine rebuilds). 2) The negative spiral: when high performance sportscars gets affordable to people who dont want to use the money for maintanence, you get even more engine failures. We are talking15-20 year old cars here..
Other failures because of D-chunking and cylinder ovaling is common by other models as well, and manly a product of age + service intensity.
So if you buy you should either get the engine IMS and nicasil upgraded right away, or have the money ready. I upgraded with larger sump and thermostat as well. Plus a total upgrade on suspension, roll bars, bearings, gear change, differential (mechanical) ++. End result is a car better than new, that will last for many years. And it can hold its own, especially off the autobahn.
That was a lot of off topic, sorry guys. But Im pretty hardcore on this subject :)
