Old topic but due to having both my Beolab 5’s getting a new chassis/main board I can add something to that.
my t’s have serial: 18883817 and 18883823. One of them failed every few hours with violent noises and the other one was not able to play anything without ticking noise over 48khz. I decided to have them both replaced. (1800€ But basically latest version speakers, refurbished with warrantee)
first repair went well and fw was updated from 2.6 to 3.20a
second repair seemed to work well but as soon as a fed a source of 96/24 that one had cracking sounds, 88.q and lower played wel. The service engineer said, they have to be able to play 96khz so we swapped the speakers to make sure it wasn’t a cable problem. i have proper 75ohm cabling, connecters and termination so the problem moved with the speaker.
A firmware check showed that the speaker with the problems had firmware 2.61. This should be possible as B&O only sends out repair kits with latest version HW and firmware. So apparently this “refurbished” kit had slipped somewhere in the QC process.
After that the engineer tried to read the error-log to send to B&O and wanted to install the 3rd unit he had in his van. While doing that we heard loud noises, the speaker kept playing after these noises. But the speaker was very hot so he opened the speaker and we were treated with a smoke show. Something defenitely had burned on the main board, so this was to be send back to Denmark.
installing the 3rd main board also failed because he rushed a bit too much and broke the connector on the subwoofer. Finally he gave up and took the speaker back to the store for proper repair and analysis.
he wanted to take some time to do this properly so they offered me a temporary loaner Beolab 5, from someone who upgraded to 50’s recently.
so far the i troduction:
the difference in power jacks ise purely cosmetic, there is no ground/earth connection internally in the speaker.the old three wire jacks only have 2 wires connected anyway. The switched the system after a request of many installers. The 2 wire cables are easier to fit through wall holes and easier to bundle with audio cables. Also most other Beolabs have these smaller connectors so upgrading would be easier.
second: the loaner beolab I now has serial 17958321 so is significantly older than my own set. Again this one is not capable of playing 96khz but also this one plays 6 db louder by default. The repair man did not know this was the case, we tried to reset everything and used different inputs put the volume difference remains. You can correct using the Beo4 but every time you power up it is back. Fortunately I use Roon so I can compensate this in the DSP setting for speaker distance.
