Hi All,
I just thought you'd be interested...
For a while now, I've been experiencing some distortion with my BL5 speakers - first one of them started exhibiting the issue - it got worse over time. Then the other one also started sounding distorted. The distortion was apparent in the midrange.
The distortion was so bad that it was possible to record it on my phone:
I spoke to a B&O repair technician, who originally suggested that I might need new chassis for the speakers. I can't say I was too pleased at this news!
However, I decided not to accept this, and try my own DIY analysis, as it's such a pain to ship the speakers around the country and I didn't want to fork out for new chassis!
So, I removed the chassis on the worse speaker. I carefully inspected the electronics. I have to say, the chassis is "beast" in one respect - there's a lot going on, but in other respects the class D amps are incredibly compact, particularly considering the amount of power they can produce!
I didn't find anything wrong, apart from some very slightly blown capacitors on the bottom board. The bottom board is the power supply for the sub bass/bass driver amplifiers. So I replaced these capacitors - the originals were ELNA 160V, 2500uF 105 deg C. I notice that such capacitors have a service life of about 2000 hours at 105 degrees C (as far as I was able to determine). I replaced them with EPCOS 200V, 2700uF, 5000 hrs at 105 deg C. Hopefully they will last the remainder of the lifetime of the speakers! I'll replace the capacitors in the other speaker when I can. I think it's good preventative maintenance.
No other capacitors were blown and everything else looked ok on the other boards.
Some photos I took while working on the chassis are here:
