Yes, my measurements are consistent and repeatable. Just ran it again with same results.
I have the mic pointing straigt up on a tripod in my normal listening position. Height like the tweeters.
Speakers are in option 0, Beovision 7 volume at 52, Overture audio source on cd, thus the Beolab 5s are prefering the spdif signal from the minimac.
The only factor I change is turning one of the mains around. The overall magnitude is very different. In the other scenario the baseline is approx. -15db, so it is a much weaker signal.
I have the FuzzMeasures on another computer, If I can edit this post from the other machine i'll insert the other scenario into this post shortly.
EDIT: image inserted ( two measurements with same setup overlay)
