Beolab 5 digital and powerlink?
Yes, it`s possible. I used my BL5s with BS7000 connected via Powerlink and BG CD7000 via spdif.
RADIO, TAPE, BEOGRAM will work via Powerlink, CD via spdif. Volume level control works via Powerlink, even in CD mode.
switching between analog and spdif works automatically. I used my BL5s with BS9000 in the same way and now with BS5.
Hope this helps.
Stefan
Flere probably means: using them with a B&O source via PL and using them with a non-B&O source via Spdif.
I'd say, theoretically yes - but you would have the swich the option of the speakers each time you'd change the input....not very convenient.
The BL5s need Powerlink with any spdif connection.
The digital signal is carried via the spdif and preferentially handled by the BL5 with minimal DAC conversion.
The PL line is used solely as a trigger signal and volume control.
So yes, a source to BL5 with powerlink will trigger the activation of sound from another source (already on) piping through the digital signal. Only problem is this won't be a coordinated signal.
If the Beolab 5 are connected via Powerlink and SPDIF, the SPDIF input is only open when the connected Beosound / Beocenter / Beomaster sends the command “CD” (this is what a Beolab Penta / 3000 / 5000 would show in the display).
Therefore the Beolab 5 needs the fully wired Powerlink cable.
Solution 1: Using an old Beomaster 6500 / 7000 / 4500 with Powerlink connections. By pressing CD you can feed the SPDIF with any source you want (e.g. Network Player, Streamer)
Solution 2: Using the Beolab in Option 1 (pressing Radio on Beo4 to switch on and control the volume) and feed them via analog line-in or SPDIF. This is the best solution if the Beolab 5 is not connected to a B&O TV.
Carlo
Simple question about that,
As I understand that 'volume control' is PL data hence the use of fully wired PL cables. But do all b&o PL sockets on even modern RJ45 systems output this data?
MMIndeed, that is what I mean. Option switching is not a good solution, so I guess the answer is no. Thanks.Flere probably means: using them with a B&O source via PL and using them with a non-B&O source via Spdif. I'd say, theoretically yes - but you would have the swich the option of the speakers each time you'd change the input....not very convenient. MM There is a tv - and there is a BV.
And can the Essence2 be used as the Powerlink master which send the CD command to the BL5 to process the digital data from another source. Probably not.Simple question about that, As I understand that 'volume control' is PL data hence the use of fully wired PL cables. But do all b&o PL sockets on even modern RJ45 systems output this data?
