Hello all
What is the best way to use Beolab 5 front speakers with Beolab 3 rear speakers with a non-B&O Surround Processor?
If we remember that:
Beolab 5 wants fixed 2V RMS line input (volume controlled on speaker).
Beolab 3 wants a variable 2V RMS line input (volume controlled from source).
If using a Beosystem 3 I assume that the Powerlink (or other voodoo) over-rides the Beolab 5 internal volume changes or sets it to a "reference" level of some sort so that it effectively meshes with the Beolab 3.
In theory with a non-B&O surround processor (assuming a maximum out of 2V RMS), I could connect the line outputs to each speaker (BL5 and BL3). Set the non-B&O surround processor to reference (ie: 0dB attenuation), send a test tone to the rear speaker and then adjust the Beolab 5 volume to match the rear speaker from the same tone. I could then store this setting for the BL5 so when the speaker is turned on it starts at this level ready to go for surround applications. Volume changes on the non-B&O surround processor would then change the volume of all speakers equally.
For stereo listening (from SPDIF/coax) I'd need to remember to turn down BL5 before playing to avoid a heart-attack!
Is this the best solution? Is there a better way (without Beosystem 3)? Anyone currently doing this or similar?
Kind regards Adrian
