Beolab 4500's Display isues
I have a pair of BL:4500's  connected up to my BS3000 . The issue that i have is that at present and for as long as i have had them, i can't seem to be able to see the led display info that is at the bottom right hand corner .Is this a conectivity issue or am i missing something here?
I assume you have the Beolab 4500's connected using the powerlink sockets and the switch is either in L or R
I am assuming the switch is not in the "A" position ?
In standby there should be a small red led next to the display
And the switch on the side of the speaker needs to be in the Audio position. You need to use fully wired Mk2 powerlink cables.
... and you have to reset BS3000 and Blab4500 to be sure it works. (unplug power cable of both unit until stby led disapear, and re-plug them).
(sorry for my english...)
