Beolab 4500 / Beosystem 3
Hi all, I'm having trouble getting my beolab 4500's to work with my beosystem 3. I last had them Woking directly from a beosound 9000. Is there anything obvious to check? Any help appreciated!
Set switch at the back of beolab on "video".
Maybe you have to take off the power from the beolab first
What does not work?
I assumed he meant the displayfunction.
Fully wired powerlinkcables are needed, otherwise the lab's will not switch on. Maybe that was changed also.
