some penta-c's here: https://www.marktplaats.nl/a/audio-tv-en-foto/luidsprekers/m1740746848-bang-olufsen-beolab-penta-mk2.html?previousPage=lr
Did you use glue to fix veneer? If so, what glue?
Hi Orava, these Penta's are not mine, I just saw the add. So I cannot tell how the veneer was bonded.
I would not be surprised if they are made by Leslie (old forummember). Maybe you can find him on another medium?
Regards, Johan
Ah, hi. Actually I ment Leo's speakers. :)
I guess Leo will be a bit offended by your question 😕
Look closely at the pictures - looks like solid wood all the way through - not just veneer glued on.
Well, I have never seen BL4000 in the flesh, but somehow covering must stick on the body of speaker. Right?
Ok, thank you. I have had little problems when glueing veneer to metal. Last time I use bostic A3 to (wet)glue veneer to plastic.
