Beolab 4000 stands and other placement options
In that case ( = background listening) it is the question, if a relocation would be worth it.
The question: ‘Would the speakers perform as well on the table stands as they do on the wall?’ is imposible to answer….before trying it out.
It will much more be the other location, that could make a difference, not the stands.
However, if you are up for a change, why not do it - it certainly won’t be worse (= less good) than now.
hi Leo and thanks for the offer - i didn't know those ones existed! I think i prefer the speakers in the vertical orientation or i'd have been happy to swap.
rather disappointingly the seller is not able to ship them. back to the drawing board unfortunately!
I have 3D printed my own. They are just squeezed into the grooves on the back of the speaker. Which groove you choose will adjust the angle.
So I guess they cost me 1 $ 😂
Regards.
R.
B&O used to make an alternative stand, it vertical positioning was wanted:
Have a look here:
MM, these are the ones I want to swap for wall brackets 🙂
Scott wrote:
My other option is to put them on small rubber feet and place them on the bookcase to the left of my desk alongside the Beomaster 1900 but in this layout it would be difficult to hide the cables.
When I got BL4000 to go along with an Ouverture I did had hard time finding table stands at descent price.I ended up DIY'ing a pair from a storage box from ikea.(To keep it nordic), It's quite easy if you have steady hand and a good knife and fairly cheap. You can find the thread on this searching by my nickname. Result was acceptable enough to wait for a pair I finally found for around 40€ IIRC.
https://archivedforum2.beoworld.org/forums/p/29143/232476.aspx#232476
thanks everyone for your input in this.
I think you have convinced me to give the table stands a try - a very kind Beoworld member has offered me a pair that he no longer needed so i will report back on how i get on with that and hopefully have some finished pictures to share on the 'flash your B&O' thread once its all set up.
I like that ikea hack idea! i need to make a trip up to my local store in the coming weeks so will keep an eye out for the storage tubs as a plan B.
