Hi chaps, I've had a look at some of the Beolab threads as I have a fault with one of my 4000s. They were new in 2007 (model with LED as a light rather than a button/switch) & are linked to a pair of Beolab 8000s, which is all set up ok.
A while ago my wife heard a low pitched pop from one on start up, result that there's no LED illuminated, no signal or sound. I've checked the mains lead & Beolink cable & they're ok. Not sure if the problem is due to the dreaded foam issue or maybe an internal fuse that's blown. Any advice or thoughts from anyone who's had a similar experience gratefully received. Thanks.
