When conncted to power plug the red indicator light comes on. However when the audio signal source is switched on the red light would normally changed to green after sensing the signal. This is not happenng now for one speaker. I swapped powerlink and power cord, thus suggesting sonething wroung in speaker instead of cables as the other speaker works fine.
The speaker started this suddenly while working fine, since then i cannot activate the green light.
Is this a simple fix?
What could be wrong? I guess something wrong with the signal sensor trigger switch. All modes line,left or right are not switching the speaker.
Than
