Jonathan wrote:
Whenever I try to use the Beolab 4000s directly I get a humming sound
PowerLink cables (like "Line" cables using RCA/Phono plugs) are unbalanced cables.
On longer distances these cables, especially the "thin" versions will pick hum.
Double shielded cables (like the recent 5mm B&O PowerLink-cables) are more resistant to hum.
Double grounding causing ground loops can also produce hum ...
BeoLab MK1 and MK2 use different power-supplys, a mixture of both types on the same output can also
lead to hum ...
A solution could be an old BeoLink converter as "Audio-Master" and 3 BeoLink Active for three zones
wired via ML Cable. MasterLink is a symetrical = balanced cable (same technology beeing used in
radio stations, theatres, recording studios and PA) and hence quite resistant to hum.
Only the remaing lenght from BL-Active to the BLb 4000 will then be an unbalanced cable.
