I have a problem with my right BL4000 speaker as I cannot get the on/off power light to change to GREEN(it is illuminated RED) indicating it is working, but it will not change to Green like the speaker on the other side of the room which is working correctly with sound.
I have swapped the left to the right and vice versa etc. The good speaker (left speaker) works fine on the right side but the fault still appears when I connect the "faulty speaker" (right speaker)on the left side indicating perhaps that it is not a cabling issue?
I have noticed recently that the speaker was "clicking" occasionally, like it was "shorting". I have checked all connections which are good.
The speakers are linked through a Beolink cable and connected to my PC via Beoport.
I am in the Algarve in Portugal, with no dealership locally so would welcome any suggestions.
I have had the speakers about 20 years
Thank you for reading.
