Beolab 4 vs. Beolab 4000
Considering the choice, I would suggest the Beolab 4000 speakers.
They sound very good as Home Theatre speakers, and can get quite loud. There have been many discussions here before regarding the BL 4000.
You may find that a used or pre-owned pair of speakers is a better value to start building your stereo system.
OR... You could consider a BeoSound 8 and connect things to that?
Get a second hand pair of Beolab 4000s - the Mk1s are in my opinion the better speaker anyway and much better than the Beolab 4.
I have had BeoLab 4's, BeoLab 6000 and BeoLab 4000's. The 4000's blow all the others out of the water in sound quality. The 4's are less then thrilling and the 6000s are great speakers unless you listen to music with lots of bass (although a BeoLab 11 cures that right up).
I would say go for a used pair of 4000's.
I have exactly the same experience than bossbrad : I've owned them all, and the 4000's are by far the best. Bl4 sound really "flat" in comparison. 4000's are more expensive, but they have a better value for money imho.
Would agree that 4000's sound very good (by a long way).
$2990 seems expensive. Be patient and wait for a good condition pair to come up on ebay for £600 - £700 ($1200 max). If you're prepared to accept minor cosmetic flaws then you can get them for less.....
Hey guys, just remembered that Tue has more than hinted that a new set of speakers aimed for laptops etc are due out around September - MAY BE WORTH WAITING FOR!
Perfect. Right when tuition is due. 🙁🙁
