I moved last december to my new house, since then my old rear speakers (Beolab 4) were just sitting on a shelf because I never did a full re-install of my old surround set-up.
A few weeks ago my iMac which I frequently used to listen to music had critical failure and I bought a new Macbook Pro 13" Retina. Although I like the machine for work - I hate the sound of those crappy Speakers.
So Yesterday I had them all three in view: The Macbook, and the two Beolab 4. I took a 2x 3.5mm cable and connected it to one Beolab 4 (it has both the Powerlink and the 3.5mm socket). I was impressed by the good sound (as a PC-Speaker).
My question is: What kind of Y-cable do I need exactly to connect both Beolab 4 to my computer? All 3 connectors have to be 3.5mm but I do not know if it can happen that I get the wrong cable?
And is there any possibility to get a nice table stand for these speakers? Actually I do not like them standing just low on the table.
Thanks for your help! As soon as my new Setup (I am going to put the Macbook in a box under the table and will use a LG 34" 21:9 monitor) is ready, I am going to Post pictures.
