In my case, since I purchased the Beolab 4's late in the product cycle, I doubt mine are from the older batches. But who knows, perhaps the dealer had old stock!
No, I think mine failed due to the generally lower quality of the power supply... with thousands of power cycles across the years, low quality shorepower, etc.
Someone suggested I should go with a different model but the problem is that these were installed on a ceiling in a sleeping cabin where they fit perfectly given size/shape, so I'll just have the failed one repaired.
Beolab 4 failure
Just done the No 100 rerair on Beolab 4.
Till now i have app 90% repair performance.
not bad..but it can be more than 15 different issue for faliure.
