Nano_Cell wrote:
Hello iridium,
One idea I have come across for doing my set-up is using the following audio processor:
link
That would allow me to plug the speakers in via RCA L&R then plug in a sub to the S/W Out. Not perfect and not exactly as cheap as I was hoping it would be but it is as good as I've found without going in to serious money. It also offers the ability to adjust the cross-over to the sub so you can get the most out of both. Not sure if there are disadvantages to this set-up in terms of sound quality.
Any opinions on this would be appreciated!
Will.
Hi Will,
I am using the Emotiva UMC-1 as a surround processor in my setup.
I have it connected to a pair of BL 1's, BL2 and BL8000.
The reason for buying the UMC-1 was because I didn't want to go on a beovision. After some research I heard about the Emotiva and it should be the best in class competing processors up to $1500 for sound quality.
If you are also using it with rears, then maybe you should not connect it to the line port of your beolabs, butmake a fake connection to the powerlink (for more information search my posts on the forum)
If you read about the Emotiva it's a lot about bugs, which don't exist anymore on the current firmware, so don't be misled.
When I first set it up, i ran Emoq and changed the settings to some actual distances, crossover, etc.
I was searching for a long time for good EQ settings, because for movies it was great, but for music I was dissapointed and thought it was much better connecting my speakers through the BL2 onto the beocenter.
But after a lot of research I was able to improve the sound quality. I discovered everything was out of phase, so that's why it sounded strange. I did run Emoq again and just left the distance settings (even where they were very strange settings). I also took the Emoq settings and corrected these settings to my own reference curve. And now it sounds absolutely amazing, even better than connected to the beocenter.
I'm really happy with my choice for the UMC, because the sound quality improved, I've got dolby surround and can use the internal DAC for my mediasources.
Funny thing is that Emoq thought the BL2 is twice as far from the listening position as it really is, so it does have a little lack, but is corrected perfectly by the UMC. It sounds very thight, powerfull and absolutely not boomy.
I hoped this helped.
