BeoLab 3500 with PlayMaker prototype
Hey Guys!
Having been asked many many times if a BeoLab 3500 could work with PlayMaker, we decided to give it a go and have spent the last few weeks developing a prototype.
We used the MCL socket on the rear of the speaker and carried out internal circuit modifications and additions so that the BeoLab 3500 is now activated by the trigger voltage from the PlayMaker (whilst maintaining on/off muting)
We have been testing it in our showroom for the last week or so and it works brilliantly!
We just wondered what you guys thought to this prototype? Perhaps this is something that could be useful to others?
Regards,
B&O Nottingham
Wow, that is something I would look into very closely as I have a spare BL3500 and currently only a Beotime waking me in the early morning!
Does that mean, that you would modify a BL3500 for a costumer...
...or are you willing to make a 'how to' for interested BL3500 owners?
Just so we are clear, will it support the ML connection at the same time as the PlayMaker? Or is this in place of?
Yes, we have many clients with a similar set up and can see the benefit of this solution
This modification would be in place of the ML connection, thus allowing the BeoLab 3500 to be re-utilised with a more modern digital set up
The modification is quite detailed and involves a lot of dismantling of the BeoLab 3500 to access the various circuits. We are still evaluating the possibility of us providing this as a service to existing BeoLab 3500 owners, depending on demand.
I'll give you my compliments for the job.
Can you explain in detail the modifications to the circuit?
The Beolab 3500 must be on the remote control or the Beolab 3500 is turned on by playmaker?
assume this could be used to work with a sonos connect, which will give more flexibility?
Hello,
The BeoLab 3500 does not need to be switched on via remote for the PlayMaker to work. Instead the trigger voltage from the PlayMaker activates the speaker. Much like a regular pair of BeoLab speakers.
Because of this, it means the user could use the BeoLab 3500 with a PlayMaker without even owning a remote control!
