BeoLab 3500 MKI to BeoLink NL/ML
A few thought. The BL3500 do have some testmodes to show if the ML connection is ok.
Menu + Menu + 0 + 2 + GO should give status for the ML connection. This will either show: ML OK, NO ML or an error number in the BL3500 display
Thanks for this info.
this option shows No Ml or Error4.
any ideas what this can be? I only could use two Ml to RJ45 cables with a RJ45 link connector together.
The error 4 is called data collision in the service manual, meaning to much trafic on the ML system. That however does not seems plausible in your small setup, so I would advice to look at the cables first.
Does your network cable have metal shielded connectors? That is a requirment as the ground for the ML connection is going through that
This is of great help. I have two old amL cables in the garages with just one connector. I think I try to solder both cable ends together and try with that cable.
I now get a ML ok but still no audio. This system drives me crazy. Do those systems have kind of a battery they use to power the saving of settings? I feel like it acts like a pc without the CMOS battery. Perhaps the system forgets the settings?
there is no factory reset for BC2 and BL3500, right?
If they have a battery it is most likely soldered, so no easy removable, and might not affect these issues.
This might be a long shot:
On the BL3500 try to acces Menu + Menu + 0 + 9 + GO
It should say ML ON. If not try to change the value with up and down arrows and accept with go.
You might have allready have tried this (so sorry to ask this) try to check the volume level on the BL3500 and try to activate the mute function a couple of times
Also if you want to double check your wirering, it is the orange/white-orange and the red/white-red pairs that transport the sound
It really was the cable.
i used a new cable (had a extremely short spare one) and now it works. The BL now shows the Time, can turn on audio and plays the sound 😍
I forgot how nice the sound of those was. Seems to be now my Garage setup or the new office setup and I get rid of the BeoSound Emerge 😉
Great to hear it worked out with the right cable 😀
