The cable you have wil not work.you need a cable from steve www.sounds heavenly.com
The beolab 3500 also need a remote to put him on and off.
good luck
good luck
Dear Gerardus54,
Thanks for your response!
FYI: the cable I mentioned does work, it has been tested and works perfectly.
That I need a remote is clear, like I mentioned before.
Though, I am interested to learn if there are other ways to switch to MCL permanently.
