Beolab 3500 active speaker HELP!!!!!!
piocrony wrote:
i used beolink converter box #1612 + master link to BL3500 + Y adapter RCA - 7 pin din
Thanks . I don't have remote control or MCL cable. Do I need to have beo 4 remote control to switch the input mode TV? If I don't have anything plugged into MCL will it start up? I need to find 1612.
MONKAB wrote:
Does anyone have clear pdf version fort BL 8000 service manual? Type MK1. Type Number 6802.
Service manual for 6802 is available on this site. Register as a silver member (or why not gold?) to be able to get the pdf. The manual cover this five versions:
Mains 6801 EU 230V
6802 GB 230V
6803 USA-CDN 120V
6804 J 100V
6805 AUS 240V
Alternatively, if you're in Australia I will be selling a few pairs of Beolab 6000s in the very near future... for a lot less then the retail price!
And I have seen them ... and they are beautiful :-)
Finally Success. Used 1611 converter instead. Works great. ML cable from converter to BL3500 and use 7 pin or 5 pin AUX din cable in 1611. Stored default audio volume, bass and treble. Press TV in beo4 and walla. Very happy with the project outcome. Now I need to find a way how to turn the BL3500 on in TV mode when I turn on the denon 4311 amp. The only way I can do is use a 2nd remote trigger from amp trigger 12v. I need to make a circuit which will short out TV button in beo 4 remote for 2 sec as soon as the amp is ON. Anyone have beo 4 working circuit board?
