Beolab 3500 active speaker HELP!!!!!!
Hi, I am new to this forum. I just bought a pair beolab 8000 and I want to buy a beolab 3500. I can't afford beolab 7000 to use as a center speaker with my denon 4311. So my plan is make 3500 as active speaker. I amy able to get one used fro $400 usd mark. I was looking at the service manual and it does have some pinout where I can get RCA hooked up. But digital signal must be fed from B & O system to activate and turn on 3500. I am impressed with the casing so thats why I am heading that way. Did anyone has found any option how to use 3500 as active speaker without linking with any B & O system? It would save me lots of headache if someone has done it already. Next option is buy active speaker amp and wire up speskers inside. So Existing circuit in 3500 will be replaced with B & O amp to accept RCA signal.Thanks in advance.
You will have to get a trigger signal from your source, seach the forum for Peter Pan connections
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thanks for the reply. getting there. Just found a third party box that will allow to use it as active speaker but 200 EURO for a PCB board is a rip off and it is not B & O supported.
Search this forum for "BeoLab 3500 center speaker".
And in those threads, I believe the general opinion was that a BL3500 (like any integrated stereo speaker) will suck as a center due to combing effects etc...
A topic much discussed in this forum. Do follow Daniel's advice and search the forum for the many threads dealing with this issue.
I'm afraid that in my opinion, you're headed down a very long dark path with this. The black box that you found is the only "easy" way of doing what you're suggesting. I for one have discouraged others from going down this path. I own a BL3500 and like it very much for what it is. I just can't imagine using it for a center channel, something it is not designed to be. But I do understand the temptation.
Much luck.
Slighty off topic, but a bit relevant.
I just wall mounted a bL3500 in our bedroom, and it just occured to me that when I listen L&R are reversed, as it is on the wall above our bed.
So - a really good upgrade to this product would be a switch that reverses Left & Right channels.
From  my days installing, I know link speaker positioning is often a compromise - and 3500 often go in kitchens and bedrooms in a location that is, in effect, behind the listener.
I will at some point break into the ML and reverse the L&R feed - I'm fairly sure there are no implications for the rest of the house - there are 4 other ML rooms, but if I reverse the L&R localy to the bL3500 should be OK.
He, he, that's why I placed mine on the wall opposite to our bed. On topic again, our sponsor sells a Loewe centre speaker for 400£, maybe that's a path to try? Click on the ad for Life Style AV on top of this page.
@Daniel
I think you're right about the Loewe speaker. I have no idea how it sounds as a center channel, but at least it was designed for that purpose.
I have seen a BL6000 used as a center channel (with a special end cap fitted on the bottom). It looked ok and sounded ok.
Unfortunately for Monkab, this approach might still be out of budgetary reach.
beo-ap wrote:
@Daniel
Loewe speaker is my last option and there are few on sale in ebay. Though I want BL3500 or BL6000 just to match with other beolab 8000. I don't have a option to check how good is loewe center. BL6000 is my next option but I have to buy a pair which is really out of my budget bracket. And not sure if I can find one BL6000 speaker for this purpose.
