Beolab 3500
The Beoworld user manual section shows the Beolab 3500 having ML and MCL connections. Does this speaker still have an 8 pin MCL socket or is an ML/MCL converter now required? Can the 3500 be operated using an MCL2AV and powerlink?
When they installed mine in 1999 when it was used in connection with a BC2300 they installed a converter. I didn't ask any questions at the time but they went from Aux on the 2300 to the converter and then Masterlink from the converter to the 3500.
BL3500's shipped in the last year or two have powerlink and masterlink. This for compatibility with Beolink Wireless.
Prior to this they had MCL and Masterlink.
What do you plan to connect it to?
I would connect it directly to MCL cable or to an MCL2AV. A BC9500 is the source.
David
Direct with MCL cable would be my choice. Or Masterlink converter/Masterlink.
Don't know if it would work with MCL2AV
So I can connect my MCL cable direct? Perhaps only to a unit that is a few years old. Looks like a new one would need a converter. Is the powerlink on this product for output only?
I have a 9300 and two 3500's. The MCL cable goes from the 9300 to the 3500. You do not need the MCL2AV for that. I have the MCL2AV, which is also fed via the MCL cable, but that is to run a pair of CX-50's.
...So will work with a Powerlink output from an MCL2AV? This would save me buying an MCL>ML converter.
Never heard of a MCL to ML converter... but anyway yes if MCL2AV has it's own Ir eye (I don't now if the display will work)
