Hi all!
I just wonder if it's ok to put Beolab 3000 panel speakers with Beolab2 ? Would there be any compatablity issues?
Any idea?
Hi all!
Any idea?
They should be a fine together.
Cabling might cause an issue - if you wish to have the displays of the BL3000's working.
Actually I think Graham is right and it should be fine. The pins 6 and 7 carry data and these are described as looping through in the service manual. Obviously if you have the 3000s attached to the receiver or TV rather than coming from the Beolab 2, then this is not an issue anyway.
