Hi!
I'm a new member but I have done a lot of googling and reading before registering.
I would like to pick your brains regarding speaker choice, mainly BeoLab 3 & BeoLab 8000/8002.
Currently I have a traditional home theater setup with 5 passive speakers, 2 XTZ 95.44 towers as fronts (picture below). These are not high-end at all.
I´d like to dip my toes further in the B&O universe and would like to avoid towers in my living room.
This is an impossible question I know, but would the BeoLab 3 struggle to act as front speakers compared to passive towers? Will they give "enough" sound pressure for movies and stereo use in a ~20-25 square meter living room?
They are rated to Max Sound Pressure 94 dB, will they start to distort in the upper regions?
I do have a subwoofer to off-load the low frequencies and also have BassEQ hardware to integrate it well with just about any speaker.
The AVR will also take care of room correction, crossovers etc.
OR, is the BeoLab 8000/8002 a better choice in this regard?
It might just be that I am ignorant towards the physical size of the 3's.
Unfortunately I wont be able to listen to any of these before purchase..
Thanks in advance for any help and input!
Current tower speakers:
