What is the best connection for a Beolab 3 to LG TV? Are there specific cables that have Powerlink to 3.5mm or RCA connections? Does it sound good? Thanks.
Beolab 3 to LG TV connection
I guess that Steve from Sounds Heavenly can perfectly do this for you... Just look down ;-)
If the TV doesn't have a variable audio output (a couple of mine do not), then you might look into the BeoPlay connection hub (which seems to be sold out on the BeoPlay site, but other sites have it - at least in the US).
Hi diggs,
Stan and Benoit have covered both options perfectly:-
1) The only way to connect the speakers directly is if the TV has a headphone socket, as this is the only way that the speaker volume can be controlled from the TV remote. (some TVs have a separate headphone volume setting in the menu, instead of using the main volume buttons on the remote - you can test this by plugging in a pair of headphones). Please use this cable to connect a pair of Beolab 3 speakers to the TV headphone socket:-
2) If the TV only has an optical output then a Beoplay S8 Connection Hub is needed (£149 GBP from your local B&O store). This converts the light signal from the optical socket to an electrical signal and allows the TV remote to control the speaker volume. Please use an optical cable from the TV to the Hub:-
You now just need one RJ45 splitter and two Powerlink cables to connect two Beolab 3 speakers to the output of the Hub:-
Splitter (1 required): link
Cables (2 required):
I wasn't aware that it is as easy as one single cable to connect my non-b&o television with BL3. I have a sony tv with something that looks like a headphone socket. I can connect a headphone and can hear audio.Besides the BL3, also possible to connect a BL2 or BL11?Thanks!Hi diggs, Stan and Benoit have covered both options perfectly:- 1) The only way to connect the speakers directly is if the TV has a headphone socket, as this is the only way that the speaker volume can be controlled from the TV remote. (some TVs have a separate headphone volume setting in the menu, instead of using the main volume buttons on the remote - you can test this by plugging in a pair of headphones). Please use this cable to connect a pair of Beolab 3 speakers to the TV headphone socket:- http://soundsheavenly.com/line-in-connection/70--trs-2x7pd-.html 2) If the TV only has an optical output then a Beoplay S8 Connection Hub is needed (£149 GBP from your local B&O store). This converts the light signal from the optical socket to an electrical signal and allows the TV remote to control the speaker volume. Please use an optical cable from the TV to the Hub:- http://soundsheavenly.com/input/149-premium-braided-toslink-optical-cable-with-metal-plugs.html You now just need one RJ45 splitter and two Powerlink cables to connect two Beolab 3 speakers to the output of the Hub:- Splitter (1 required): http://soundsheavenly.com/bang-olufsen/27-rj45-powerlink-compatible-splitter-new-powerlink-to-two-8-pin-din-powerlink-compatible-sockets.html Cables (2 required): http://soundsheavenly.com/powerlink-8-pin-din-connection/20-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html Kind regards, Steve. Steve. www.soundsheavenly.com Sounds Heavenly are proud to sponsor the BeoWorld forums!
Steve1977 i think the trick is that once you can hear your headphones in the TV, if you adjust your volume on your remote does the headphone volume change? If so, then it would be one cable :-)
Otherwise nothing can change the volume and they will be at one high volume
Unfortunately there is no headphone jack so I have to go with the optical way. Thank you all for your help.
I think this works. i used to have an A9 connected to it (using line-in) and could change volume with my tv remote. I somehow thought connecting to ML was more difficult than just a cable.what about the BL2? can use cables to connect BL3/BL2 combo?Steve1977 i think the trick is that once you can hear your headphones in the TV, if you adjust your volume on your remote does the headphone volume change? If so, then it would be one cable :-) Otherwise nothing can change the volume and they will be at one high volume
Hi Steve 1977,
Yes, you can add a Beolab 2 and Beolab 3s (although these don't have their own volume control like the A9, so they rely on the TV headphone socket to be volume controlled).
Your Beolab 2 subwoofer needs a powered cable to generate the trigger signals that would normally be sent from a B&O television:-
The Beolab 3 speakers will then plug into the two output sockets on the Beolab 2 using standard Powerlink mk.3 cables (one cable is needed for each speaker):-
