elephant wrote:
However I find the sound of the BL4s particularly satisfying and intend having several in the surround sound set-up when we get to that stage.
If I had an unlimited budget (is that a contradiction in terms?) I would ADD to my setup the following:
In summary: for me the choices are as much about HOW the set-up is used as how it sounds as all 3 speakers have a place in my lifestyle!
Thank you so much for your time and effort in this answer Elephant! It really helped a lot. I let three of your statments remain as a quote:
BL4: Is that to say that you find the BL 4 to be most satisfying as long as they are not required to rock the boat? I have a set of BL 9 (highly recommendable!) and there is only open space, however a couple of corners between them and where I would put the BL 4's. Normally they would play from the same source, but on occasion it might be that the 9's has tv as a source and the 4's play a CD or similar. Both would of course have to consider the other regarding volume :-)
My question is really: BL 4 is a third of the BL 3 price. Would they do the trick? To me, an output of 2 x 35 watts sounds a little... whispery... at least compared to the badaboom of the BL 9's. Maybe that is where it gets clouded for me. I most certainly do not expect them to play like the 9's, but it would be nice if they had a story to tell, so to speak.
Oh, and yes, I think the words "Unlimited Budget" are a huge contradiction in terms.. :-D
So finally. Of course people can not compare lifestyles in a forum. It will never be accurate, but the room in question is only 12 sqm, opening up to another room of about 30 sqm, opening to another of about 12. That is where the BL 9's are. Based on this, (and I will never come after you for this one) do you think 4 is enough money spent?
Thank you so much again!
