Beolab 28
There actually is a wall bracket from B&O for it - so they must have thought of how that will work.
25.3 w x 137 h x 25.3 d floor stand
21.2 w x 140 h x 25.3 d wall bracketN.B. Why it is wider on a floor stand us hard to imagine :-o
Hallo MM;
You can see it in the app, The base turns so you can have it on the wall.
Yes, I have seen it there.
But the placement does not change the width....the base is just turned.
There’s most likely a mistake in the measurements. The depth should change when mounted on the wall, not the width. From the pictures I posted, it would seem that when the bases are folded over, the speakers would become less deep. Which makes sense, as you wouldn’t want them to protrude from the wall to much. With DSP and room correction, from spec, these are very advanced speakers.
Have just seen them at the dealer,
Some answers.
Both speakers can be master/Slave you just choose in the app.
They have the Mozart platform chip as the Level and Emerge, so upgradable in the future.
The opening is used to narrow and wide mode, so not just for show.
They do Wide mode like the Beolab 90, not like the 50.
They are a bit more expensive then Beolab 20.
They do look better in person, but it is very different from what we are used to from B&O.
I did pick up the Emerge on my way out, nice little speaker, my Beoplay Portal Grey Mist is first in stock the 6 of may, had hoped to get a pair today :(
How was the sound?
As they can only show them today/tomorrow and they just got them today, they were not setup properly.
But I can say one thing, they do not need a subwoofer.
Thanks!I have a 7-55 with 50s. I would like to get a 65 inch Eclipse or Harmony but do not have enough room with the 50s. I have been toying with downgrading the 50s to 28s to allow for the upgrade to 65 inch Eclipse or Harmony and very much like how the 28s look.As they can only show them today/tomorrow and they just got them today, they were not setup properly. But I can say one thing, they do not need a subwoofer. Beovision Harmony 77" 2nd Gen, Beolab 5, Beolab 17, Beosound 1, Beoplay M3, Beoplay H6, Beoplay Earset, Beoliving Intelligence
Emil, this is great. Did you take any photos you can share with us? And how do you think the bass performance compares to BL19 or BL20?
Raz, I sent you a direct message about your 50s.
That would be a downgrade both sound and picture.Thanks! I have a 7-55 with 50s. I would like to get a 65 inch Eclipse or Harmony but do not have enough room with the 50s. I have been toying with downgrading the 50s to 28s to allow for the upgrade to 65 inch Eclipse or Harmony and very much like how the 28s look. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
You took my words right out of my mouth, was almost afraid to say.
But yes indeed, it does look like a toilet plunger - that would be a good nickname for it.
