Beolab 2500 how do i remove the fronts to clean the cloth
Is it possible to remove the front grills of my Beolab 2500 , I have the instruction booklet but it doesnt say whether you can or not!!
They are black cloth fronted
Just put your finger through the fabric hook the frame and pull
Is that a joke answer?, put  your finget thru the fabric!!, not on your Nelly
Please clarify!
see my reply to your earlier question !
finger nails also work - top and botton between the fabic panel and its close fitting surround gently ease it out and the panel will spring out - its not difficult!
refitting fit one side then just press other side home - again job done
tony s
Brilliant thread.... not laughed so much for a long time.
What's the old 1st world war joke.. junior officer at the front line tells a messenger to go to the General and say "send re-inforcements, I am going to advance". After transferring the message to other runners and transferring over poor telephone connections the General finally gets the message "send three and four pence I am going to a dance"
Gordon
