Hi Steve,
Thanks for the quick reply, the reason I ask is that I have found a site that claims to have your old cables in stock ?
best wishes
Ken
Hi Steve,
best wishes
Ken
Hi Ken,
I would be very surprised at that, as I haven't sold them for quite a number of years now!
Kind regards, Steve.
Hi Ken,
I have sold these cables to them several years ago, but I am very surprised if they still have these cables in stock...
Hi Steve,
You can still place an order on the site. I have an old beolab 2000 and wanted a cheap solution so that I could use a audiocast S as a stand alone speaker in the garage. I think the question is, did the cable work ? or should I just thoughthe beolab 2000 out.
best wishes,
Ken
Hi Ken,
Sorry I can't comment on this. I doubt that the company still has any of the cables that I sent to them several years ago. Sorry I can't help further with this.
Hi Steve,
Thanks for your help
best wishes,
Ken
Hello, sorry to see that some information seems not to be found any more which i found about 3 years ago (? maybe I am wrong…)
There I did use the BL2000 for some weeks instead BL7 while I had to have a look for a new one. I remember it was able to activate the BL 2000 without ML and feed it with line in input by (1) configuring the BL2000 in some way and(2) activating with Beo4 in a distinct way. However, this information seems to be deleted? can anybody help me, how to activate BL 2000 without ML input or w/o the converter?
many thanks! Chris
many thanks! Chris
Dear all,
first, sorry for the double post, I cannot delete /edit any more. beeing a forum member since almost 15 ys - I believe so ;-) - these are my first posts.
second, I just found the solution.The BL 2000 settings were changed after having it running in a REAL ML setup.
Here
