I have the BL2 in conjunction with BL3 for music. No regrets at all.
Only word of advice I have is, do a demo with your components - maybe in home if you can. You will note differences in sound from TV to TV used .....
This is all really interesting stuff folks, thank you. I think I will ask for a demo in my living room (which is not palatial, and I do have neighbours..) to feel the force of the sonic volcano. I have to say that 99% of the comment is positive, so I guess I should really not waste time analysing the 1% of negative/indifferent feedback.
Happy listening.
C
I am expecting BL11 to be a much better performer than it is expected...
I had Beolab 8000 as fronts and Beolab 6000 as backs before, and a BL2 is almost a MUST! Just that now I've upgraded to BL9 and the BL9 have a strong woofer component so I've sold mine.
Not only you get much stronger and definitive bass, the fact that the subwoofer is doing all that work frees up your BL8000 too. You'll hear the sound coming out of your BL8000 a little crisper.
The only downside is as everybody knows the BL2 is a tid-bit slow. Sometimes the rumble at very low frequencies is a little too much especially for fast beat music. But for movies, it'll blow everything away.
Definitely get a demo if you can and I'm sure you won't want to return it to the dealer once you've heard it. :)
I have the BL2 in conjunction with BL3 for music. No regrets at all. (...)
Same here... I think I couldn't live without the BL2 [:'(]
I have read a huge amount of positive information....I am thinking about adding a sub to my set-up (BL8000s front, BL4000s rear) and was wondering if anyone had any negative comment about the BL2...
No, there's been plenty of negativity, too. That's one reason why they've created the BL11.
I sold my BL2 after a year. Used it for music and found it didn't seem to keep up. Particularly fast dance music. Moved it to my TV setup, with my BL9s and found it didn't add much value *apart* from key explosions where it would really rock the room and, as you say, disturb neighbours.
I disconnected it for ages, then decided to use it to trade up to BL5s (which were later sold for other reasons!).
I think I am going to get the neighbours involved with this purchase and see if they give the thumbs up!
keep it only 2 weeks then SOLD. Then I had the B&W PV1 and was very happy with it.
Now I have Beolab 5 and everything is different!
regards...
I think they are so good I have two! One for the avant with four 4000s and one for the 8000s in a separate room. The 8000s are bass enhanced but I turned the bass off and let the lab 2 do what it does best. I would not ask the next door or they just might listen harder!
I have also an Avant, BL8000 and BL4000 + BL2. The subwoofer does a GREAT job IMHO.
Cheers,
