talfaia wrote:
Hi Oli, this is great. For music, where do you have the volume control? In the TDAI2170 or in the BL5?
Not in the TDAI. The Lyngdorf permits passive speakers connections only to use with the Preamp/Amp part of it.
The BL5 are connected in SPDIF to the TDAI-2170, and also in Powerlink to the BV7-55. So, more specifically, the volume control is adjusted by the BV7 as it is one of the rare BV models being able to send the data control through the Powerlink MKII cable to the BL5 (I think, to be confirmed, it is limited to the Beovisions using the Beosystem 3 in them, so BV7, BV9 and BV12 MKI).
The BV7 is also opening the SPDIF port of the BL5 through the CD command to get the digital signal from the Lyngdorf. It is why you see a Beomaster 4500 linked to the BV7. I use it sometimes for the FM, but it is mainly used as a CD command receiver on the Beolink, even if there is nothing connected to the CD input of the Beomaster.
There is multiple advantages to not use the integrated volume control of the BL5 when you are in an hybrid setup like me (with B&O and non B&O stuff):
1/ you have a full Beo experience regarding Video and Audio integration (no need to switch the L.OPT on the Beo4 each time your change the source), piloting everything with the Beo4 with BV PUC or with the addition of a well known Lintronic box.
2/ the source and the volume setting is visible on the BV7 whatever you are sending to the BL5 (the TV screen remains off)
But we are off topic, to be back on it, Mr_ander_son, if you are happy with your BL18/19, you might keep them and improve the acoustic experience with an active or passive room compensation, It is my advice. If you want to step up, go for the BL5, but it would be a pity to not consider the acoustic treatment of the room also while doing it, to fully enjoy this piece of audio art that is the Beolab 5.
I suggest everyone to read the excellent blog of Geoff Martin about room compensation topic:
