Dear All,
I need your help to understand and, maybe, solve the issue (if it's really an issue...).
Remark: I already created a post with this issue but in the French forum...
So, I noticed that in no particular cycle, my BeoLab 18 and BeoLab 17 turn off and on (= red LED, then green LED). It happens while running or in standby mode. But sound doesn't seem to be cut.
Front left speaker may does that issue two or three times before an other speaker does. It can take several days between. It happens randomly.
These four speakers are connected to my BV7 via Transmitter 1 (BT1), Wisa technology.
Installation was done by my dealer.
Transmetter was exchanged two times already.
DIN 8 pins to RJ45 PowerLink cables were replaced too (they are B&O genuine, not home made).
The Transmetter is located on the BV7-55 stand, in the middle H+V place / screen.
Product Status Indicator of the BT1 is orange continuously whatever the system is running or in standby mode. That means the wireless signal is too low. So. But front left BL18 is located at around 1 meter, front right (BL18 too) at 2m, rear left (BL17) at 3m and rear right (BL17) at 5m. Between BT1 and rear speakers there are the BV7 and a sofa (no metal inside except fastenings). Between front speakers and BT1, there is nothing. Direct view.
My dealer seems to be overwhelmed.
Do you have any idea about this issue?
Is there a know issue with the BeoLab Transmetter 1?
For safety reason (my wife 😁) I will not use coper wires but keep wireless as long as I can.
Many thanks for you support.
Take care,
Tux
