Beolab 18 + beoconnect with WISA
Hi all,   is there a a way to make one of this 2 setup: - connect 2 beolab 18 with a beoconnect with WISA - or connect 1 beolab 18 with a beoconnect with powerlink, and the second beolab 18 with WISA connected to the first beolab 18   thanks for your help
Unfortunately not. The Beoconnect Core doesn’t have Wisa built in. You could connect the Beoconnect Core to a Transmitter 1 and then connect the BL18s via Wisa, however the downside of that approach is that you lose the ability to optimise the output of the Beoconnect Core to the BL18s.
You can connect one BL18 to the Beoconnect core via Powerlink, but then you need to connect the first BL18 to the second via Powerlink as well.
Ok thanks for your answer 🙂
