corle48 wrote:
The problem is that they both play right channel
Hi
Had the same issue with my BL17s. Here is what I did:
* Reset the hub with a pin by pressing the reset button on the back.
* Reset the RIGHT speaker by pressing the reset button till you get a flashing green light (if the BL18 works like the BL17…) AND unplug it from the main. Leave it unplugged.
* Reset the LEFT speaker by pressing the reset button till you get a flashing green light. AND unplug it from the main. Leave it unplugged.
* Start configuring the hub: pair the remote and start the Chromecast process until it ask if you heard the sound.
* Plug only the LEFT speaker to the main, and immediately press shortly the pairing button on the hub. Wait a few seconds for the process to finish. Unplug the speaker from the main.
* Plug only the RIGHT speaker to the main, and immediately press shortly the pairing button on the hub. Wait a few seconds for the process to finish.
* Plug the LEFT speaker to the main.
* Press “try again” in the Google Home app in order to hear the test sound. If your hear nothing, restart the app and try again to configure the hub (not the pairing process !)
Hope this helps.
corle48 wrote:
For now, this wisa standard, doesn't seems to be as easy as it's said....
You’re right…
