I recently bought a Beolab 14 5.1. Figured since the Beolab 14 comes with the D-SUB15 plug with 10 speaker wires so I purchased the Denon x2400h without the pre-outs instead of the Denon x4300h that does.
Followed the direction on the manual to have the speaker wires connected to the AVR while setting the Beolab 14 MODE to AMP, PHASE at 0 and LFE to +10dB; however, when I plug in the power cord the system started making this loud buzzing noise even with the AVR turned off.
Originally, the Beolab 14 power cable was connected directly to the wall plug while the AVR to extension cord so I switched it over to the extension cord think it might be interference but that didn't solve the problem. Only when I switched the MODE to LINE did the system stop making the loud buzzing noise; however, I know this is an incorrect setup because LINE is supposed to be used when Beolab 14 is connected to the AVR using RJ45 to Phono.
At this point I am not sure what else to do. Any help would be greatly appreciated. Thank you!
