I had mine setup the same way (CEC TV - Yamaha Receiver via D-SUB). I don't have it hooked up that way at the moment because I bought a pre-amp... but I'll be returning it and going back to my original setup (that's a whole other story).
If you can live with it for the time being, once I reconnect everything back the way it was (probably next week or so), I can tell you at what volume db my speakers turn on. I know our receivers aren't the same, but it should give you a gauge as to whether your unit is requiring a higher signal to trigger on.
