If I remember you have a set of BL 17 and BL 19 - is that correct?
If so, you would not need a BL 16 which is another subwoofer.
However, if you do not have a BL19 then indeed buying a BL 16 which is a subwoofer would work well and be an alternative to buying a BL 19.
It would be connected via the the same amplifier that you would be getting for the BL 15, however, you would in that case need another Receiver 1 if you want to do your connection wirelessly.
I would mount the BL 16 in the wall rather than ceiling because of size, and just run the cable behind the wall from the amplifier.
By the way did you ever get another Transmitter 1 and did this solve the sound noise on your BL 17?
