BeoLab 12 with floor stand ?
BeoLab 12 is an on-wall loudspeaker.
But, maybe B&O could bring a floor stand for this speaker or a new BeoLab 12-2 model ?
I remember Roger was talking about two BL 12 models and saw a picture of the BL12 on floor stand on a spanish dealer website.
I think the BL12 on a floor stand could perfectly match my floor stand BeoVision 10-40 ! 🤒
Do we know any informations about this ?
It can never be a floorstanding loudspeaker as it needs a wall behind it to create bass from the rear mounted speakers, so wall mounted will be the only way to have them. They do look great though, especially with the 10-40 as they are the same height.
Yes Martin, it's true !
Thanks for the answer.
So, maybe a small on-wall BL12 to match the wall-mounted BV10-32...
What a pity !
Steph the 12-2 is a small version. About 50 cm tall. Price tag is 12 500 DKK
Thanks for the info ! 😕
MartinW wrote:
It can never be a floorstanding loudspeaker as it needs a wall behind it to create bass from the rear mounted speakers...
My dealer told me there WILL be a floorstanding version of the BL12s as B&O want it to compliment the BV10. He said it will follow, but I forgot ask how they'd handle the bass issue. Perhaps it might be floorstanding, but has to be close to a wall? :)
If not, and he was wrong, I'll get some BL3s instead.
